- Feb 26, 2007
awsome vids
No. In threads where I've discussed the technique I use, e.g.does everyone move the blade that fast?
Push cutting newsprint has improved my sharpening skills dramatically, with certain blades I can push cut at over 4" on newsprint (compare the numbers I was getting in the threads linked to above with those in my infamous JYD2 review. For me the "secret" to achieving this kind of sharpness with a very fine, polished edge (coarse edges at very low angles can show impressive push cutting on paper as well, BTW) was learning to finish sharpen with the very lightest of pressure on fine ceramic Sharpmaker or CrockSticks. I don't strop, and in fact feel hand stropping only risks degrading an edge of this caliber ... however I believe using a system like the EdgePro with the fine polishing tape, and again the lightest of pressure, should be able to exceed what I can do by hand.I have a hell of a time getting past 2" when putting the blade against the paper and literally pushing. I got a very clean cut at close to 6" with that chopping like action, starting the motion about 3" above the paper (zdp caly).
I know what you're saying, and 8-9 months ago I would have agreed that that pretty much applies without any real equivocation. However this gets back into the issue of using extremely light pressure when applying the final edge, and in fact being moderate with the use of pressure throughout the whole sharpening process.I think it's worth noting that unless I'm whittling soft wood, those extreme push cut edges don't last very long, but the cutting ability lasts for quite a while due to geometry. If that makes sense.
Okey-dokey...
http://www.pendentive.biz/blades/40sheets.wmv
http://www.pendentive.biz/blades/AKBowie4.wmv
http://www.pendentive.biz/blades/cleaver.wmv
http://www.pendentive.biz/blades/magvid1.wmv
http://www.pendentive.biz/blades/magvid2.wmv
(though not perfect draw-less push cuts...gives an idea)
I have to try the typing paper test that Sodak described, sounds like another crown pleaser.
Mike
Hi, hardheart. This got me curious, so I tested some Dex "yellow pages" paper against the newspaper newsprint I've been using for months. Freshly sharpened EKA 12C27 blade pushcuts the Dex paper at 4.2", the newsprint at 4.1". I really thought the phonebook paper would be more difficult to cut because it's thinner than the newsprint -- they mic out at .0023" and .0028" respectively -- but not the case.what's the difference between distances on newsprint and phonebooks? I can get 2-2.5" on phone book pages, can a guess be hazarded as to what that would be for one of you on newsprint? All my newsprint is leftover filler from shipping, or papers from three years ago that have been sitting in a corner (USA Today & Financial Times, whatever quality paper they use). I think the humidity (S. Louisiana) and being stuffed in a box makes it weaker, but it's hard to tell.
Agree, db. For me consistency is the overiding concern when testing sharpness with newsprint, so my technique has evolved accordingly. One thing that I find very important to consistency is to have a clean, freshly-cut edge on the paper; much better results if the paper is cut to size with scissors rather than a knife. I size all my paper test "media" to 5 inches of length, and so that I'm cutting perpendicular to the direction the paper wants to tear cleanly (if that makes sense.) Width of the paper I've found isn't so important, between 2"-3" wide gives the same results.Hardheart, Im guessing because I believe the paper test is so Technique dependent that it is probably not good to try and relate one persons results to anothers. Your 2.5 could very easily be anothers 1.5 or 3.5 using the same knife and piece of paper. Then just think of the difference in paper quality from different places. Also how far of a cut into the paper qualifies as a pass, cut in two, half way down the paper, or just a little about the with of the edge bevel?
Just for fun. I put a Shapton Pro 1000 grit finish on a knife of mine. This is a pretty coarse finish, more coarse than the Spyderco med. hone. I was able to press/push cut news print right around 4 inches from my hold. It also sliced up cardboard like a hot knife cutting butter. It's a little coarser than I like but it was fun to cut with. I'm rethinking real coarse edges.
