- Jun 19, 2003
I use S.S. steels almost exclusively and at the higher temps to harden have had some welding of the tool wrap to the blades before. Last night,though ,was ridiculous. I was soaking three D2 blades at 1875 degrees for 40 minutes. One of the blades, because it was curved to be a belt knife, was to be oil quenched. It went fine---been there,done that. The other two, also wrapped in#321, were tossed between the quench plates mounted in a vise. I had to use a single edge razor to seperate the tool wrap from the blades after the cryo and before tempering. What a pain! I have some higher temp#309 that I keep for BG-42, etc.,that I don't think I should have to use at 1875 degrees. Because the curved blade popped out just fine from it's packet, I'm thinking the quench plates more or less forged the packets to the two other blades. Other than using #309, does anyone have a solution?
