Phillip Patton
- Jul 25, 2005
Howdy!
Well, it's been awhile since I contributed much to this forum, so I decided to share something that has made my life a lot easier. Maybe you all are using techniques and tooling like what I'm about to describe; if so, forgive me for wasting bandwidth.
Anyway, here goes.
I like recurve blades. A lot. And it just so happens that many of my customers like them too, which means I make them now and again.
Now, recurves are not the easiest blade to grind, in fact, probably the most challenging, particularly the "inside" curve. That area is just a pain to try to grind well using a flat platen, because the edges of the platen like to grind grooves there.
So, I decided to make a grinding attachment for grinding that inside curve. Here it is:
The surface is leather (richard j gave me the idea for using leather. Thanks Richard!), which I ground to a radius which pretty closely matches the curves on most of the recurve blades I do.
Here you can see the curve on the surface:
Here's what a blade looks like coming off the grinder using this attachment:
