Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
Yesterday I took a trailer and two friends and we went up to see Ron Frazier......well it sort of felt like he was there. We went up to see what could be salvaged from his shop. His widow, Susie, was charming and gave up the tour of the house with all Ron's and her crafts and art work. The house is really comfortable and there is a treasure or unique item at every turn.
We found a path...well sort of a path....to the shop in the woods. All around the shop there are Lady Slippers ( wild ground orchids) growing on the woodland floor. Outside the shop is what you would expect, a pile for thirty feet in all directions of things tossed out or used up. Inside was pretty much the same. It was a foot deep in magazines, boxes, broken tools and junk, and whatever Ron wanted to toss on the floor.
There was about 1 Sq.ft. of work counter cleared enough to set anything down, and the rest was a foot or two deep in STUFF. We started clearing the work counters , and as we did, it was sort of like having Ron there with us. We would pick up a piece of a knife and say, "This is the frame for one of Ron's coffin handle bowies.", and one of us would pick up a book with that knife on the cover, and then we would find a bowie blade to fit it on the floor....and so on. At one point, I said, "Well Ron, I'll take good care of this stuff for you, and do you proud. " I looked up for some reason when I said that....... and realized the ceiling was full of knife blades....yes, Frazier dagger blades and other small blades were sticking in the plaster ceiling. I guess when Ron was bored, he would toss them at the ceiling...and a dozen or more stuck.
We would talk about Ron as we went, just like he was with us.
The work drawer was filled about 6" deep with every small thing that you could imagine. The bottom had about 1" of metal and sanding dust in it. As we went through the items/grit/dust, parts and pieces of folders and mini's, and daggers,....and Bowies, started to appear. There were about twenty knives in the drawer...... many with the handles temporarily pinned in place. Some were cemented to the drawer bottom by dried oil, time, and dust ( we pried them free)
Most of the main grinding equipment was in pretty poor shape, so we left that. Many hand tools and small items were salvaged. There were thousands ( yes thousands) of magazines and books on the floor and shelves.We took a storage box full of really interesting books, but I will have to see if they can ever be used, as they were covered in grinding dust and pretty musty.
The hot shop roof was starting to fall in, but we salvaged a very old small Paragon HT oven and the NC Knifemakers forge, and a few other pieces of equipment. His four burner sword forge was too bulky and fragile to try and move.
When we finally got everything hauled out to the trailer, we had:
A 30L dewar for LN
Small Paragon Oven
NC Knife makers forge
MIG welder ( not sure if it works)
Barber chair hydraulic base
Roll of HT foil
30" round kiln top to use as a hot table
Bag full of belts and sand paper.
Moran style Knife vise
#100 hand tools and such
50# of assorted handle wood
Rolls and rolls of leather and skins (lizard,snake, etc). We took the ones that were not damaged, and left the damaged ones.
2 dozen briar pipe blocks - drilled and ready to carve.
Contact wheels, buffs, a few tooling arms, etc.
full case of 12" cut off disks for a chop saw.
50#+ of books on Japanese swords, Knives, Bowies, Animals, etc.
#30 of stag crowns and scales, many pre shaped and drilled for his knives.
Jigs and templates for his blades, frames and handles.
#20 of jade blocks and slices
#30+ ivory handle ( most pre shaped) MOP, Fossil walrus, Oosik, Dino teeth, claws,and bone.
#50+ of blades in various stages of completion. Some are HTed, marked,and have handles ready to glue up and just need a little surface rust cleaned off, others are ground on one side only, others need HT, etc. These range in size from a 1/2" mini to a 24" sword. Most are at least 75% finished. There was a small box full of folder parts and blades along with his plate jig for fitting the backspring to the blade. One folder was completed and had the rivets run through the stag scales, but was never peened.
There were also dozens of metal collars and tips as well as wooden sheath cores he was making. And a few pounds worth of bolsters, fuchi, spacers, guards, etc.
I have a box full of his wooden and metal mandrels for shaping tips and collars.
I found some more wall decorations and old farm items for my shop and yard, too.
One last thing we found was a cigar box full of arrowheads and Indian tools. Ron loved Indian and primitive culture. It also had some bear and raptor claws in it ( hawk??).
There is a bit more that I will check out on a second trip, but this is the bulk of the salvageable items.
A 30L dewar for LN
Small Paragon Oven
Roll of HT foil
