Mistwalker
- Dec 22, 2007
Well, Im doing some work on the house since I came back from vacation
so not a lot of time lately. But, I did get out for a little while the other afternoon to walk through some local woods and play around with a couple of new pieces of kit. The sun was bright so in some cases I adjusted the shutter speed to pull in some details on lighter colors which gives the photos an interesting light.
Lots of thistle popping open
Lots of Ocoee out too, with some nearly ripe, and more to come.
The Coyotes carry corn cobs from the fields off in to the woods to eat so you find corn growing in odd places.
Not sure what this is yet, any ideas?
I was traveling light, but never know where Ill end up so the Janus kit I had in my shoulder bag. The contents are Wenger Ranger SAK, Suunto MC-2G, some band aides, alcohol pads, and gauze, a plastic fresnel lens, whirl pack water bag, Katadyn water purification tabs, a small light, a fire rod, fishing line and hooks and a few other odds and ends
I really like the lower sighting window of this compass more than the higher sight of my other sighting compasses.
A turkey feather I should have brought home and turn into a quill pin
I played around with the trapper some while I was out. Its really well set up for fire-crafting.
The new model Fire Tool is made by Exotac Inc. and incorporates a lot of their standard features such as the knurling and a threaded and replaceable rod. It holds enough PJCB tinder to start a few fires under decent conditions and probably one or two in a down pour with proper preps. The rod itself can be used to pack the tinder.
Finding a good piece of bark for a base I used some of the thistle I had found earlier and some dry leaves for tinder to start a fire. I left just enough thistle exposed to catch the sparks, flash flame, and ignite the leaves.
A curious visitor stopped by.
Then since it has a bow drill divot in the handle I decided to give it a go as a bearing block. I made a quick two-stick hearth and spindle from some of the Yucca I had in the truck
It was a nice afternoon break, hopefully Ill get to do it again soon
