A Tactical Straight Razor?!
draggat
Last week, I was placing an order for some traditional Italian knives, from Italy of course, and I stumbled upon the Extrema Ratio T-Razor. I have to admit, it's a bit of a preposterous idea to make a tactical folding straight razor, but the uniqueness of it really caught my attention. I'm not sure how useful it really is, nor if I'll ever even use it, but I had to have it.
This, along with the Resolza model that I ordered at the same time, is the first Extrema Ratio knife I've owned. ER is Italy's answer for the tactical loving folks in Europe. They don't appear to be readily available here in North America but I do see mention of them occasionally on the forums. Although the designs do look a bit different, they are actually very comfortable in hand. The fit and finish are superb. Solid early lock up on the liner, perfect blade centering with no play in any direction and extremely sharp out of the box. I'd say the price is comparable to American tactical knives.
The T-Razor comes in either a satin finish or all black. I chose the satin finish because, hey, if you're going to have a straight razor weapon, the other person needs to see the light glinting off of the blade.... IMHO, it adds an element of fear to see a bright shining razor coming at you. The blade is an extremely thin high hollow grind. It truly does have the grind of a traditional straight razor and I've no doubts it would make an exceptional slicer. It would work very well in the kitchen but after reading ER's description of the knife, it's apparent that they designed it to be a weapon.
It is easy to open with one hand, but lacks a thumb hole or stud, so it's not a fast deployment. Blade retention is decent although it will partially open if you wrist flick it hard enough. I havent been able to fully open it that way although im sure you could loosen the pivot if you so desired. Another thing that most Americans will hate is the lack of a pocket clip. I'm not sure why they left it off this model, but personally I don't like pocket clips so it's a non issue for me.
Specs:
Blade Length: 3.9"
Overall: 9.6"
Blade thickness: 3mm
Weight: 4.6 oz
Steel: Bohler N690co @ 58HRC
Handle: Anticorodal anodized aluminum
Nylon washers
Finally, some pictures!
The very best there is. When you absolutely, positively got to shave every motherf****r in the room, accept no substitutes. :D
That looks like a rather serious..."shaver."
I will stay out of Italian bars.
Really more of a tactical knife heavily inspired by straight razors, since it seems to not actually be designed with shaving in mind, but I like that pivot tension adjustment lock, and the build quality does look nice.
I think Strider (Brous maybe?) made insane custom straight razors that were pretty sweet.
I have the ER Resolza which is a modern take on the classic Sardinian shepherd's folder. Very slim and narrow profile so even with a 4.7" blade it disappears in the pocket. Also, no pocket clip nor thumb studs.
The modern take on Resolza and T-Razor is aluminum handle, N690 stainless steel and a liner lock.
T-Razor circumvents some of the Italian knife laws because it does not have a pointy tip. It's a novel albeit perhaps not so practical design.
:D:thumbup:
Looks like a handy box cutter. I like the look of the indexed pivot with set screw, but knowing my luck the blade tension would be perfect right in between two of the indexed points. :grumpy::D
Kinda reminds me of the Böker Haddock:
The Haddock is actually a framelock with a reversible clip, and the spine is 0.20" - a very robust full hollow grind. It was my first Böker Tree Brand knife, and I've been keeping a passive eye out for another as I really did enjoy the one that I had. While it has a nail nick, the high hollow grind allows you to middle-finger-flick or push the blade open with your thumb, and the ceramic detent ball combined with phosphor bronze washers gives it a very smooth pivot action.
I do wish more companies would make knives with a straight high hollow grind. The Spyderco Byrd Cara Cara Rescue PE was the last one I had owned, which I ended up switching out for a Yojimbo so I could have a pointier tip. I would love to see a straight high hollow ground knife with a reverse tanto tip...
and when the cuttin' was done the only part that wasn't bloody were the soles of the big man's feet, ooh.
A real straight razor design wouldn't lock up straight with the handle though. Being able to rotate past 180 degrees is pretty important to get the right holds during a shave. Not that this appears to be truly designed with user functionality as the primary consideration. Interesting piece.
