- Jan 12, 2013
You are correct Bill but this does not appear to be one of the earlier 25's with the press fit stop pin.. the only reason I say that is it looks like it is a screw head.. and the press fit stop pins did not have a screw head on the lock bar side. But I of course could be wrong.
All the best, Dave
You are right Dave, my 25 has the newer screwed-in stop pin, not the press fit. I do not remove it because I can't!!!!...and lord knows I've tried!!! CRK put so much lock-tight on that screw, and torqued the living daylights out of it on the lock-bar side that the only way I could remove it would be to use pliers and scratch everything up. Having said this, I feel this is perfect, and is perhaps what CRK intends. There was no lock-tight on the front slab screw for the stop pin, so I just leave the stop-pin attached to the back slab and never have to worry about aligning it after cleaning or maintenance (for the noobs out there, the 25 stop-pin has a flat side that must face the blade or they interfere. The original 25 had a press-fit pin, and the new ones are just screwed in).
