Test between GB and ER:
Picture 1: pull cut
Cutting test on an 8mm polypropylene rope.
GB is much sharper.
Picture 2: push cut
Cutting motion while applying force on the spine, same rope.
GB is much sharper, better edge geometry.
Picture 3: edge holding ability
Pulling the edge several times with light pressure over a peace of steel (St-37 construction steel) and testing the cutting ability on the rope between the steel strokes.
GB has better edge holding.
Picture 4: grip
The handles of the knives where completely oiled with Ballistol.
GB has better handles and better grip.
Picture 5: tip strength
Ok, it gets nasty now. Knives where forced through a 2mm St-37 construction steel plate. The GB bent to the side, but got back to its true position and had no damage to handle, liner or pivot. At a pressure of 85 Bar (86.7 kg/cm2) under the hydraulic press the tip broke of exactly in the moment the blade went through the steel plate.
The ER folder failed the test, at 65 Bar (66.3 kg/cm2) the lock bent and failed (secondary lock not activated otherwise the handle would crack/explode).
Picture 6: lock strength
Both passed the obligatory spine whack test with flying colors. Under the hydraulic press the ER failed at 70 Bar (71.4 kg/cm2) again without the secondary lock engaged, otherwise the handle would crack.
The liner lock of the GB disengaged at 80 Bar (81.6 kg/cm2). The extreme pressure left no damage to the lock. Knives still worked flawless.
Picture 7: blade bending
The S 30 V powder steel blade of the GB was surprisingly flexible. At 30 degrees and a pressure of 83 Bar (84.66 kg/cm2) the blade broke.
The thicker blade of the ER (6mm) made out of Austrian Böhler N690 steel passed the test and did not brake even at the maximum pressure of 85 Bar (86.7 kg/cm2). The blade was only 2 degrees off center after.
Picture 8: pivot strength
The whole GB (liners and scales) bent, but got back to its original position after the test!!! The pivot and lock was fully functional after the test. At a pressure of 80 Bar (81.6 kg/cm2) the outer ring of the male pivot screw broke off, but the pivot still worked after that.
The ER also passed 80 Bar (81.6 kg/cm2), but the aluminium handles and steel lock bar stayed in the bent position and the knife could not be used anymore.
