Gizler00
- Feb 19, 2006
So I cut up a few more things to show its ability for some.
I have a few tires that need to be disposed of. Some of these were already cut up by my millie, and others still need to be trashed. So I figured I would see how the Praetorian completed the task.
It took a little bit to initially get through. Obviously this knife has a thicker tip and penetrating something like a tire will be more difficult than say using the military or something similar. It also does not help that I had cut up quite a bit of cardboard prior to this which dulled the tip slightly.
Anyhow, once I was able to get the knife through, the hollow grind sliced the tire up with ease.
Where are some pics for you guys.
Coating took a bit of a beating.
Also had some serpentine belts to toss in the trash, so I figured I would see how the Praetorian handled this. Serpentine belts have fiber cords inside of them for strength, sometimes making them difficult to cut. With these, I simply wrapped the belt around the blade while holding the knife in the reverse grip, then pulling back to make my cuts. Not an issue at all.
As you can see the blade it gunked up from the tire and belts. I am going to have to touch it up later this evening when I get home.
Again, I will report as I make more progress on testing this thing out.
