- Mar 27, 2012
Hello,
I would like to post a work in progress for my latest knife. It is a mix of a seahorse whittler blade and a Tony Bose gardeners handle. I have made a few of these and so far i am just trying to make each one better than the last. This is not step by step really but just something that may spark the interest of a new knifemaker. It also starts post heattreat. Any veteran knifemakers out there, please be free with comments or constructive criticism. I have crafted eight knives so far and I have a lot to learn, but it sure is nice when one turns out like you pictured with your mind's eye. This knife is not available.
Here goes....
-- 154cm Blade and spring stock back from heattreat and nickel silver liners milled and roughed out.
[/url][/IMG]
-- Rough tang to spring fitting working towards the goal of flush backspring at closed, half stop and open. Note aluminum piece is hollow to fit over pivot bushing and to hold it in position. Pivot bushing is clocked to keep measurements the same through assembly.
[/url][/IMG]
-- Blade grinding guide in place to clean up grind lines post heattreat. I am still saving up for that VS Burrking with a 20" wheel to make this quicker....
[/url][/IMG]
-- Another shot of the blade while working through the grits. It is clamped to my file jig that has turned into a great work holder.
[/url][/IMG]
-- Cleaning up the spring and getting the spring thickness close to blade tang thickness.
[/url][/IMG]
-- More work on the rise and fall rig. I am now working on the kick and blade edge to backspring clearance.
[/url][/IMG]
-- Tang and spring fitting. Grinding the kick also changes the measurement for the spring when closed. I have some work to do to hide the tip of the blade.
[/url][/IMG]
-- Soldering the bolsters. I do one then used a jig to align the other. I wish I stopped to take a pic of it.
[/url][/IMG]
-- Cleaning up the bolsters and trial fitting the knife. It is looking fat at this stage.
[/url][/IMG]
-- The mess that happens...
[/url][/IMG]
-- Fitting up some nice ebony scales. I also drilled and deburred the scale mounting pin holes and cleaned up the excess solder.
[/url][/IMG]
-- Gluing the scales on the liners. I used a two part epoxy with a good working time.
[/url][/IMG]
To be continued...
Here goes....
To be continued...
