Thumbstuds and I don't get along great even bare-handed. I suppose I should have thought to add that as a requirement.Only one of your requirements I'm not sure about it fitting is the easy-open with gloves; how are you with thumbstuds?
Wow,, just looked up the Hultafors. For $15 I hardly care if it gets lost or broken and I won't feel bad about beating it up. I carry an Opinel occasionally, so I'm used to carbon steel care. I know I listed corrosion resistance, but seriously, at $15 I'm not too worried about it.![]()
Spyderco was my first look, but how well will the Pacific Salt hold up to prying? It's got an FRN handle and AFAIK no steel liners.It's hard to believe that nobody has mentioned the Spyderco Pacific Salt..
Actually, Salty, H1 is an extremely tough steel. The plain edged variant is no super steel when it comes to edge retention (think aus8) but you would be hard pressed to find a tougher stainless steel. It also sharpens up super easy and takes an extremely fine edge.
A. True
Okto, as far as prying goes, if you are talking about things like twisting out staples with the tip I think it would be one of the better folders you could choose. H1 toughness + the reinforced Pacific Salt tip would make it as suitable for that kind of work as most any folder I can think of. I prefer a bit pointier tip so I tend to grind the spine down on mine but given your intended uses the stock tip might be ideal for you.
B. Also True
I beat on mine really hard on a daily basis and haven't even been able to make it squeal.
C.True as well
I cannot recommend the Pacific Salt enough. Replaced my Recon 1, Utilitac II, Byrd Cara Cara 2 and Resilience as my go-to always be prepared EDC.
It won't disappoint you.
Tough as nails. Dependable.
The Pacific Salt is essentially the Endura in H1 steel.How does the Pacific Salt compare to the serrated VG10 Endura? I know that VG10 is decent as far as corrosion resistance as well, just wondering if there's a significant difference.
A serrated H1 blade will out-cut anything else Spyderco makes. But a serrated VG10 ain't far behind.![]()
