Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
As to the blade shape.
If you look at Brock's link, you see the spine tapers down more gradually to the tip, instead of a rapid drop like yours.
The bevel rises higher, and the tang has no machi ( shoulders). The bevel should be 50-60% of the blade at the heel.
The blade you have is wider than needed because of the ricasso being wider than the tang.
Normally, the bevel rises to meet the line of the tang bottom, and the tang top is the extension of the spine lines.
These changes are not too late to make.
Grind the ricasso up to the tang bottom and grind down the sine to the tang. If you want to keep the machi, make them half as deep.
Make the spine drop more gradually to the tip.
You also need to taper the tang a bit.
Once the profile is cleaned up, continue grinding your bevel up to the new line.
