why NOT profile on a wheel? The wheel is much more aggressive in my experience, and the abrasive lasts longer. Then square things up on the platen.
I started with a hardened D2 platten and wore it out m. Then switched to glass and never looked back. Static is a result of the weather and can be negated by using a static wrist strap.
I have glass on mine and get shocked every few seconds but only in the winter in the cold dry air. A bit of static guard spray works really well. I've heard you can also take a wire brush and mount it to the grinder so the bristles run against the inside of the belt. Connect a wire from the bristles to the frame and you golden.I recently put a ceramic glass liner on my platen. I have had zero of static electricity issues.
Make sure, if you use glass to have a little shelf for it to sit on so that if it does come loose it doesn't fall between the bottom roller and the belt and explode.
Great, thank you!I have glass on mine and get shocked every few seconds but only in the winter in the cold dry air. A bit of static guard spray works really well. I've heard you can also take a wire brush and mount it to the grinder so the bristles run against the inside of the belt. Connect a wire from the bristles to the frame and you golden.
Great, thank you!I just use the cheep ones that you can buy for computer repair. Thy are cheep and have long cords that attach to the wrist strap with a snap. Something like this is what I use, just clip the alligator clip to the grinder frame somewhere.
