It's not obvious from the composition why 52100 > A2 > O1 in toughness. Maybe it's the quality of the steel itself?
The old tool steels book shows the same thing.
Hoss
I totally think it does.![]()
Hoss
Yes.Is that the O1 I did?
Toughness is very complex, we don’t always have simple answers. It could be that O1 has lower toughness due to more carbon in solution. A2 and 52100 have lower carbon in solution because of the chromium additions. And 52100 has finer carbides so it is tougher than A2. Or there could be other factors.It's not obvious from the composition why 52100 > A2 > O1 in toughness. Maybe it's the quality of the steel itself?
I usually think of air hardening steels as being easier to heat treat because quenching is less critical. And 5160 and CruForgeV toughness testing we have done shows that low alloy steels are highly sensitive to overheating during austenitizing. I think the reputation of low alloy steels to be "easy" to heat treat is kind of misguided. Easier to harden with a torch or a forge, yes, easier to get a good heat treat no.
That is very interesting. I would have not expected A2 to be lower on the toughness scale than high hardness CFV as A2 is generally promoted for its inherent toughness at the expense of some abrasion resistance compared to say D2. It looks like it has more of the latter than expected but considerable less of the former.
I wonder if the CFV vanadium pinning the grain boundaries is part of the toughness.
Maybe. CFV appears to be kind of weird. Adam Desroisiers said that it acts funny if you get it below 59Rc or so. It certainly has a good chunk of vanadium.
There is so much to learn. I was sure up until this week that A2 would be tougher than 52100. The fact that z-wear/cru-wear is tougher with double the edge holding is just amazing. I commented to my wife how rather testing has shown most of my observations in real world use to be true. The extent of the difference is amazing.
@Stacy E. Apelt - Bladesmith is working on some salt pot heat treated 52100.
I would like to see comparison between that two 52100 steel and say with steel used in NSK ball bearing or with one of SKF explorer series bearing . ....I’m comparing two supplies of 52100 with slightly different compositions. One with 0.92% carbon, and one with 1.0% carbon. I’m curious about this too.
Just because there are steels that are tougher doesn’t mean A2 is “bad.”Thanks for another great article, Larrin.
I'm surprised that A2 isn't showing higher toughness - I figured it would beat out CPM154. In my experience, it takes a fantastic edge, and doesn't dull with the same characteristics as stainless steels I use, but I don't really have good vocabulary for or a way to quantify that.
Is there some 154CM in the testing pipeline? I think that's a good one to peg the improvement of the CPM process over standard.
Well A2 is tougher than both D2 and O1 which is what it typically replaces.Is perhaps the reputation of A2 being very tough that it can have good results from a broad range of heat treatment?
I don’t think any 154CM is on deck. I would also like some more CPM-154 tests to confirm the initial result and to see different hardnesses.
