01 makes a good blade as does A2.
I thought O1 had better wear resistance, and A2 had better toughness?
...best for very thin(about 1/16"
thick) small blades? Thanks.
I have done 1/16 A2 and I still give it 20 -30 minutes, probably does not need that long but the oven is on autopilot. How are you planning on heating, electic oven? gas forge?
...looks like the right soaking time at the right temp is a must for a sound HT, specially with the more complex steels. Thanks.
They both have too much alloy for me... Just sayin.
You've got it backwards. I don't care what the charts say. O-1 is a bit tougher than A-2, but A-2 has better wear resistance.
Are you implying that some simple steels would match or equal O1 & A2 with regard to wear resistance and toughness? If so, would you mind saying/mentioning them too also?Thanks Don.
I think Don's referring to the fact that they're deep hardening steels, and you can't create much of a hamon.
Yep... Very Well said Nathan!Yeah, perhaps. But I think there may be more to it than that. The alloys and the carbides do a lot of great things for steel, but the perfectly homogenous simple steel has (in my opinion) the best potential for fine edge stability. Generally speaking, a simple steel gets sharper easier than a complex steel, and will tolerate more nonabrasive abuse. The best fine edge stability I have personally ever observed was in a W2 blade (just a pinch of vanadium for grain refinement). I don't think there is a knife out there that will chop a 2X4 in half and still tree top hair, but if there were, I wouldn't be surprised if it were W2.
