- Aug 24, 1999
Ding-blastit, grabble-furkin' ringading sabble-rabble...
Alrighty, then...now that THAT's out of the way...so, I FINALLY got me some ITC-100 to line the Hellmouth (my Frankenforge) with. Mind you, after events of the last month, it's been sitting on the shelf for a month, but that shouldn't matter...it was unopened.
Anyway, so yesterday I go to apply it. I read the instructions, such as they are, which basically go something like this:
1. Mix 1 pt. ITC-100 with 1/2 pt. water.
2. After removing any loose fibres, dirt, etc., from the subject to be lined, dampen the surface with water.
3. Spraying the ITC-100 will give the best coating.
Well, nobody ever mentions that ITC-100, due to a) being the consistency of playdoh, and b) having a bunch of silicates in it, doesn't really mix well with water. Sure, you get a nice, brownish slurry, but you also get a goop at the bottom (mind you, this is after stirring with a whisk for thirty minutes) that most chocolate-milk-lovers would KILL for.
Then, when I got to the point of actually "spraying it in..." I'm at a loss. The stuff is too heavy for my spray bottle to draw up!! So, I wound up just painting it in, trying to get the most even coat I could. AAARRRGGHHH!!!
Am I missing something? How are you guys that use this stuff applying it? How many coats are you using?
