Jack of All Blades
- Nov 12, 2017
I don’t mean to say the Delta HT is better or worse than Busse’s. Just specialized for different applications. But yeah I agree INFI naturally is a stronger steel through composition.I think anyway you test you can fudge things. If you swing the blade, you can swing light with one and heavy with the other. And results will be obscured by the unfair tests. Creating a jig that uses a mild steel bar that impacts the edge at the same velocity every time would be best. Regardless of what blade is tested, the bar hits at the same velocity and same force. Unfortunately charpy testing is not very relevant for knife blade geometry. Regardless, I would give overall toughness edge to INFI. I don't believe Delta HT is better than Busse and having seen what Busse's 3V can do, which I didn't think 3V could do ever, my guess is INFI with it's lower Carbon content will be considerably tougher, but will have less edge wear resistance.
