To really distinguish wootz steel from other steels and to be sure that it really is wootz, you either need to know how and from what it was made, or you need a metallographic research process.
Wootz steel is a non-pattern welded heterogenous steel with a relatively distinct layering.
By the process of pattern welding it is possible to produce heterogenous layered steels that optically look exactly like wootz, but are technically completely different. It is not possible to produce the same structure as wootz by pattern welding.
Why?
Well, the layers of pattern welded steels are made from just that, two or more different steels.
The structure of wootz consists not of two or more different steels. It is made from one solid block of ultra high carbon steel, which is heat treated in a very complicated and lengthy process to let the carbides fall out and concentrate along and around of traces of alloy metal impurities. After the process you end up with a matrix of low to medium carbon steel which supports layers of pure, extremely hard iron carbides. The structure technically has a very strong resemblance with today's modern composite materials like fibre reinforced polymers. That's why this steel is so special.
Achim
