What is NoLita?I was in NoLita last week for work
I generally prefer a SAK (Huntsman or Farmer) over a Leatherman. I snapped a Leatherman pliers (Wave) with only hand pressure, but never broke a SAK.
What is NoLita?
I mentioned earlier
I recommend the 4" Irwin Vise-Grip long-nose locking pliers to go with a SAK
I served many years in an army rescue (from fallen building unit-reserve) where we had 30 complex tools to use
I constantly used this little 4" Vice Grip that I carried in my cargo pants
- very strong holding capabilities
- very powerful wire cutter
- long reach
- can hold very small items and when you choke it quite wide
- will hold unassisted, locks with one hand
- very light, even when combined with a SAK, lighter than a multitool
- Inexpensive to buy
- easy to use, no butterfly opening
However when going for a day hike, or even a whole weekend sleeping at a mountain hut... a SAK is sufficient. Also now most of the climbing gear is adjustable without tools (if you have been stupid enough not to adjust it at home!). I also carry a pair of lined leather gloves, which are double duty for rope management and handling hot pots without ruining expensive climbing gloves.
I find myself carrying my Leathermans more often in a urban environment than in the outdoors.
I carry gloves too in my day pack often. I picked that up from Mykel Hawke as he always had a pair of gloves on in his Man Woman survial show and it made a lot of sense. I also tend to carry my Vic Spirit more in an urban environment where weight doesn't matter much and I generally don't have anything on my belt.
Before the Leatherman came out, I carried a 4" Vise-Grip and an offset screwdriver: flat head bent 90° one way, phillips bent 90° the other.
The 4" vice grip with the needle nose is my most used pair of vice grips. It gets used nearly every day in my house namely because the knob came off on my washing machine and I use the vice grip to grip the screw/nut to turn the thing on. I also keep one in my tool box, actually one in a couple tool boxes. The Robo-grip pliers are my most used pliers. Wonderful design. Never tried bending a screw driver intentionally. Guess it depends on the kinds of things you need to use it on.
No need to bend a screwdriver yourself. They come pre-bent. Google Offset Screwdriver.
I find it interesting that things I find incredibly useful (scissors) others have never used and have no use for. It would be nice to have a bushcraft multitool that you could easily build to your own specs, and change around as needed.
Yeah I wish they could put on a thicker blade out of better steel.
I'd keep the diamond/wood file
I'd keep the glasses screwdriver
Mine has a bit driver with a flat and Phillips screw head. I wish leatherman would offer a bit with a carving chisel like on this carving jack.
http://www.japanwoodworker.com/Prod...Handed).aspx?gclid=CNvevqik88MCFUlk7AodE1UAMg
I'd keep the saw.
I'd ditch the can opener because I don't carry cans backpacking.
I'd add some sort of very small pointed blade to bore holes and stuff.
Never had a use for scissors or the cork screw on any pocket tool and I try to avoid them. I have mental categories that roughly view SAKs as a knife with tools, and Leatherman multis as tools with a knife. I pretty much like most all of these tools on either side. I do however tend to prefer a Leatherman multi when metal detecting in the bush. It can double as my bean can opener and needle nose lifter off the fire. And or remove a snug battery pack / tighten screws on the detector. A multi has performed most of this and more for me out there.
