- Feb 16, 2006
hello all.....ok i am in no way trying to bash the abs....just to find out what people think.....as far as testing procedures in the abs-there is the bend test....the rope and cuting the 2 by 4......i understand what the tests are supposed to accomplish i think at least......i have heard quite a few people say that they would not necessarily want a blade like this to actually "use"......my understanding is that when you are able to produce a blade that can pass these tests that you have control over your heat treating methods and everything else that goes into forging a blade......now my question is-
do you think that these tests should be changed?.....are there other tests that you think should be included?.....would you want a blade that passes the test to use?-if not why would you want those tests.....shouldn't they incorporate a blade that is of "high performance"........again i am not trying to open a can of worms here.....i like what the abs does and appreciate all of the hard work all of you guys do.....my main question i guess is-why use a blade for the test that you wouldn't want in the field or doesn't perform the best?......ryan
