Abuse? I'm afraid you do not know the meaning...
S7, as someone said is jack hammer bit steel. 5160 or sometimes referred to as OCS (old chevy spring) it is what GM used to make the leaf spring on the back of pick up trucks out of of, might still I don't know for sure anymore but at one time that was the steel in the leaf springs. Finally, INFI and SR101, I have a SKYCO 1311 in SR101 and that thing is stupid tough and yet holds a decent edge.
5160 is not tougher than 3V. For knife purposes, I'm not even sure that it is tougher than L6.
Absolutely toughest steel is H13, followed by S7, then 5160, then 3V/A8 mod/INFI, you gain edge retention as the toughness goes down and vice versa (in general).
I am not sure what Busse's proprietary heat treatment is for INFI. As a matter of fact, that term is almost redundant in that INFI is a custom "blend" made exclusively for Busse. As for "proprietary" heat treatments for 52100, typically they start out by austenizing at around 1475F instead of the 1500F+ you would use if you were making big bearings where large primary carbides for serious abrasions resistance at lower hardness levels were the goal. No telling who figured that out first because Busse does it with their SR101 labeled steel, but Bob Kramer by all accounts, "nailed' the HT for 52100 a number of years ago. But the trick of austenizing below the "saturation point" for increased toughness and the ability to take a super fine and very stable edge is pretty much common knowledge now. That is why it is a go to steel for custom kitchen knives. If you think that kitchen knives are left too hard to be tough, watch the video from the CBS Sunday Morning show from a few years back where Mr, Kramer does the BAs performance test with one of his chef's knives with no damage to the blade. He says that his damascus blades are not that tough and they obvious contain steel that has nickel which is one of the most common alloying elements used to increase toughness.
S7 while tough would never be a knife steel choice for me... it doesn't get hard enough (max is Rc55 if I recall)... 3V is perfect for hard use. Fine grained, fairly high Vanadium, very tough... and can be made decently hard while still tough (Rc 61-62). Its the only choice I would make for hard use/abuse knife.
