The Acebeam T36 is a dual switch tactical LED flashlight equipped with a Cree XHP35 HI LED, features 5 brightness levels plus a strobe mode and powered by single rechargeable 21700 Li-ion 5100mAh battery. The Acebeam T36 delivers an output range of 2 lumens to 2000 lumens with a beam distance of up to 303 meters. Equipped with a built-in USB-C charger makes charging convenient and up to 3 times faster than normal USB charging. The innovative side switch allows quick and easy selections to all available lighting modes. The aggressive strike bezel and dual switch operation make the Acebeam T36 an ideal flashlight for self-defense and every day carry.
Main Parameters:
LED: 1*Cree XHP35 HI LED
LED Lifespan: 50,000 hours
Power Source: 1 x 21700 or 1 x 18650 battery
Max Output: 2000 lumens
Peak Beam Distance: 303 meters
Peak Beam Intensity: 23,000cd
Max Runtime: 28days
IPX Rating: IPX-8
Impact Resistance: 1.2 meters
Brightness Levels and Runtime (Using 1 x 21700 battery):
Ultra Low: 2 lumens ( 28 days )
Low: 200 lumens ( 12 hours )
Medium: 500 lumens ( 5 hours )
High: 1350 ~ 650 lumens ( 10 minutes + 3 hours )
Turbo: 2000 ~ 800 lumens ( 1.5 minutes + 2.5 hours )
Strobe: 1350 lumens ( 3.8 hours )
Product Features:
● Aircraft grade aluminium body structure to withstand harsh environments.
● Premium Type III Hard Anodised anti-abrasive finish prevents scratches.
● Ultra-clear tempered glass lens with anti-reflective coating can be used in the toughest of conditions.
● Tactical strobe mode disorients an attacker without excessive force, therefore keeping a user at a safe distance away from an assailant.
● Smooth reflector creates a far-throwing, tight beam.
● Tactical knurling for firm grip, even when wearing gloves.
● Acebeam T36 flashlight adopts dual switch design to accommodate different scenarios and user preferences.
● Intelligent highly efficient circuit board design for max. performance and long time time.
● Tactical ring maintains a comfortable grip, also prevents rolling on a table.
● Built-in charging indicator notifies a user when a battery is fully charged.
● Battery adapter allows for the use of an 18650 if desired.
● Rubber cap for fully waterproof and dustproof, submersible to 5 meters.
● Specially designed for military, law enforcement, self-defence, hunting, search & rescue and outdoor activities.
Its long-lasting power, rechargeable battery, dual switch design and other features make this flashlight impressive. If you are also impressd by it, GearVita provides its purchase link for you: https://gearvita.com/acebeam-t36-rechargeable-flashlight-2000-lumens.html
Related products:
https://gearvita.com/klarus-xt1a-tactical-led-flashlight-1000-lumens.html
https://gearvita.com/olight-m2r-warrior-led-flashlight-1500-lumens.html
Main Parameters:
Max Runtime: 28days
IPX Rating: IPX-8
Product Features:
Related products:
