- May 29, 2004
Somewhere on the paperwork that comes with Gflex, I remember reading that it was recommended to actually wet sand the epoxy into the surface. Makes sense to me though I have yet to try it.
Me too, hollowing out an epoxy reservoir has been widely recommended around here, as well as numerous epoxy pin holes, will be considering this point very closely. Question: peel forces on very thin flexible blades like fillet and kitchen slicer knives with or without bolsters. How can we minimize the risk of failure in these cases? More mechanical pins maybe?
Also it sounds like the recommendation of cross hatching is an important key correct? How do we go about creating the undercuts?
BTW thanks very much for this, very interesting.
I would be honoredThe Traditional Bowyers Bible had a chapter on glue and the results they found were similar results though they were just gluing wood and other natural materials. Great information. I hope it goes into the stickys.
Thanks for this topic , you answered us lot of questionI would be honored![]()
The metal shavings mixed with epoxy is like what we in the US buy as "JB Weld" (which is basically a metal powder impregnated epoxy). Its claim to fame is that it withstands high temperatures better than ordinary epoxy. Why, I do not know - if the epoxy it uses is just standard epoxy, then that portion of the adhesive should degrade at high temperatures regardless of whether the metal is present. maybe they use a special epoxy that is more resistant to high temperatures?
Sir, first I would like to express my respect for your work and sharing your knowledge and by no means am I an expert or do I pretend to know better. I am quite new here and only made about 50 knives so far, some failed, luckily most still are in use.I would think they would help ... unless you have shrinkage of the handle... which could cause shear as the handle shrinks in either the long direction of the knife, or towards the top/bottom of the handle.
Thanks for the answer. And yes, It is an old thread, and I was actually trying to find answers on a completely different topic but as so often I got lost in all the info available on the forum.The issue about thinness really does presuppose that you have enough roughness on each side of the bond to supply presence of adhesive in the areas where those scratches on opposite sides cross each other ... with enough roughness you will not be able to squeeze that out (it is trapped).
the issue about defects is not so much the number of defects,but the worst defect - failure will occur at that worst defect. If you reduce the number of defects (cleaning surface, reducing the amount of adhesive present) you are reducing the likelihood of a single defect being present that is bad enough to fail given the stress applied ... it is just a numbers game.
the point you make about the adhesive layer being a “buffer” between materials that may expand differently is reasonable ... but the problem is that as you increase thickness you increase the probability of having present one of those fatal defects. Pick your poison I guess.
this is an old thread, so I will stop there, less a moderator yells at me.. PM me if you want to discuss more...
If you had failure with a metal to metal bond... was it after grinding? Excess heat will kill epoxy, independent of how you prepped or squeezed the surfaces (don’t ask me how I know... :-(. )Maybe if it works it just works. I didn't mean to discredit his advice because it's clearly good and balanced.
I just have had failures with glueing brass on brass with epoxy (clean and roughed up).
I'm just trying to find out the absolute best way to glue up scales.
Probably just need to do more research on glues, especially their behaviour after 10 or more years.
Oliver - first, thank you for your question and comments - it is just that we recently had a discussion about posting to old threads - and the jury is still out with regard to whether this forum want to allow or discourage that activity.... In this case we will let the moderators decide.....The other thing is that if you have defects, air, dust... whatever in your glue surface it will get less in absolute terms but probably will take up a higher percentage of the volume and thus make it weaker. As an analogy I would take the minimum thickness of concrete that has to be X times the size of the included granite to be strong. Squeeze the concrete out and you are left with mostly defects.
