- Dec 30, 2008
So, i took apart my grippy and lubed up the washes with my favorite grease. Yes, i usually use a teflon lube, but i've found if i apply the grease right it lasts longer and won't collect pocket lint if it doesnt get all over everything. So I did that, smooth as butter. When i got my grippy i could pull the axis lock and the blade would fall out. It did this with the teflon lube too. It also would do this with the grease but i realized it had a bit of side to side bladeplay( with the teflon and the grease, don't remember if it came like that.), and that drives me nuts ever since i learned knives had it! So, i can flick it both open and closed fine, but when i pull the lock it doesnt fall out. I don't know if it came from the factory a tad loose, but theres no medium. It either falls out with a little blade play, or doesnt with no play, and i'm pretty good at hitting that spot. So, do your grippys do this too or do they fall out? I got one of the flat black clips for it though, so it looks sweet. Wasn't too keen on the painted one.
