Depends on what you are doing during the transition. When switching back, all it does is to add the amount of hours to prevent the next date turn. Since 99% of the time I'm in the air travelling back to the US, having the date wrong for the duration doesn't matter to me.hwyhobo said:Adjusting your watch back at that point would affect the date, wouldn't it? Or can I separately and independently adjust time without touching the date?
Don Luis said:I've had a Seiko 5 for several years, the date adjust is similar to other mechanical watches, you can pull out the crown fully to adjust the time or partially to adjust the date.
From the partially pulled out position, turning the crown clockwise will advance the day number, turning it counterclockwise will advance the day name, they only go forward but it is easy and fast to go all around the 31 numbers or 14 names (they come in two languages).
Luis
Yes this happens in every mechanical watch with date that I know off, you have to manually advance the day to 1 five times per year. It would be very complicated to change every month correctly using gears in a mechanical watch, even if you don't consider leap years....each month is 31 days, always ...
That's sad, I think that they are good and not expensive. I bought mine at a mall in Mexico City and I see them often over here, not many different models though.Seiko does not make many automatic watches available in the USA...
