Which are the best, most critical items needed in the event of a natural disaster, SHTF scenario, zombie apocolypse, etc? We at deltaoutdoorsman.com have put together a collection of setups in a backpack that can help you "survive" a 72hr. scenario where major civic services are disrupted and where you could possibility be fending for yourself until aid arrives. This is not a complete setup in the sense that what is included here is all you need. Far from it, I think the general consensus is that each SHTF/Bug Out Bag should be customized by each owner based on their geographic location, most likely situation, etc. This pack & included gear covers your basic necessities of light, shelter, fire starting ability, first aid, and water purification AND uses a larger pack that makes carrying added gear more comfortable than what is possible from smaller pack setups. From there, you can add what you consider other necessities.
Again, we started putting together this kit together in late 2011 by researching the perfect pack to act as the host. The Fox Tactical Hydro Assault Pack has been chosen as the host for the gear for the following reasons:
segmented layout with numerous molle webbing points for you to add accessories, pouches, etc.;
nearly double the carrying capacity as a Compact Assault pack;
durable zippers & nylon material that resist well the hazards of being thrown in & out of vehicles, bounced around in on an ATV, and water resistant in damp weather (note: NOT water proof, you'll need to cover it in a downpour);
waist belt is fully adjustable and uses integrated side pads, which adds in comfort & stability when carrying larger loads;
the survival & first aid items as part of this kit fit are easily accomodated within the FOUR external, removable pouches, leaving the main cargo section completely unused for you to add your personal and/or family's gear;
dedicated internal hydration pouch, which is lined for easy clean up & protection of your gear in the event of spillage;
Here is what is included for the Advanced SHTF / Bug Out Bag setup:
1: Fox Tactical Advanced Hydro Assault pack in Tan/Coyote;
1: Aquamira Frontier Emergency Water Filter System;
2: Emergency Ponchos (in OD Green);
1: 2.5 Liter Hydration Bladder;
3: Emergency Glow Sticks, green;
1: Tactical Trauma Kit, with QuikClot agent;
2: Survival/First Aid Kits (contents listed below):
Bandage Materials
5 Bandage, Adhesive, Fabric, 1" x 3"
3 Bandage, Adhesive, Fabric, Knuckle
3 Bandage, Butterfly Closure
1 Bandage, Conforming Gauze, 2"
2 Dressing, Gauze, Sterile, 2" x 2", Pkg./2
2 Dressing, Gauze, Sterile, 3" x 3", Pkg./2
2 Dressing, Non-Adherent, Sterile, 3" x 4"
Bleeding
1 Gloves, Nitrile (Pair), Hand Wipe
Blister / Burn
1 Moleskin, Pre-Cut & Shaped (11 pieces)
Duct Tape
1 Duct Tape, 2" x 26"
1 Duct Tape, 2" x 50"
Fracture / Sprain
1 Bandage, Elastic with Velcro, 2"
Instrument
3 Safety Pins
1 Splinter Picker/Tick Remover Forceps
Medication
2 After Bite Wipe
2 Antihistamine (Diphenhydramine 25 mg)
1 Aspirin (325 mg), Pkg./2
3 Ibuprofen (200 mg), Pkg./2
Wound Care
4 After Cuts & Scrapes Antiseptic Wipe
3 Alcohol Swab
1 Tape, 1" x 10 Yards
1 Tincture of Benzoin Topical Adhesive
3 Triple Antibiotic Ointment, Single Use
The Trauma Kit addition gives the user the ability to address more serious injuries until professional medical attention can be received. The contents are listed below:
Bandage Materials
4 Bandage, Adhesive, Fabric, 1" x 3"
2 Bandage, Butterfly Closure
1 Bandage, Elastic, Self Adhering, 2"
2 Dressing, Gauze, Sterile, 4" x 4", Pkg./2
1 Dressing, Non-Adherent, Sterile, 3" x 4"
Bleeding
2 Gloves, Nitrile (Pair), Hand Wipe
1 QuikClot Sport 25g
2 Trauma Pad, 5" x 9"
Blister / Burn
11 Moleskin, Pre-Cut & Shaped (11 pieces)
Instrument
3 Safety Pins
Medical Information
1 Comp. Guide to Wilderness & Travel Medicine
Medication
1 After Bite Wipe
2 Ibuprofen (200 mg), Pkg./2
Wound Care
6 After Cuts & Scrapes Antiseptic Wipe
1 Dressing, Petrolatum, 3" x 3"
1 Tape, 1/2" x 10 Yards
2 Triple Antibiotic Ointment, Single Use
Finally, the Survival Tools contained in the Survival Pouch give you the critical ability to start a fire, keep warm with the survival blanket, and signal for help with the signal mirror and whistle. A breakdown of the contents is listed below:
Bandage Materials
2 Bandage, Adhesive, Fabric, Knuckle
4 Bandage, Butterfly Closure
2 Dressing, Gauze, Non-Sterile, 4" x 4"
Bleeding
Blister / Burn
Duct Tape
Gear Repair
3 Cable Ties, 4"
3 Cable Ties, 8"
Instrument
1 EMT Shears,
5 Safety Pins
Medication
2 After Bite Wipe
4 Ibuprofen (200 mg), Pkg./2
Survival Tools
2 Aluminum Foil, Heavy Duty, 3 Sq. Ft.
1 Compass, Button, Liquid Filled
1 Headlamp, 2 watt LED w/ headband
1 Heatsheet Survival Blanket
1 Magnesium Fire Starter, 4.5 mm, w/ Striker
1 Mini Rescue Flash Signal Mirror
1 Mini Rescue Howler Whistle
4 Nylon Cord, #18, Braided, (10 ft. 100lb test)
1 Tinder Quick
Wound Care
3 After Cuts & Scrapes Antiseptic Wipe
1 Povidone Iodine, 3/4 oz
1 Tincture of Benzoin Topical Adhesive, Vial
This pack & gear setup is fairly thorough and addresses the vast majority of needs in a SHTF scenario. Again, we do recommend that you customize your pack based on your specific geographic region and perceived needs.
Price is $179.00 SHIPPED to your door within the lower 48 states (AK & HI customers add $12.00 for shipping). We're going to throw in for FREE your choice of either a Condor Watch Cap or Contractor Cap. We've received numerous bulk order requests for this setup so please get in touch if you want multiple packs & we can give you a custom price.
Thanks & just ask if you have questions. PLEASE CLICK HERE to the deltaoutdoorsman.com website for checkout.
Thanks
Ceylon
(901)334-6808
