In addition to the Sodbuster Jr (3 5/8" closed), Case also makes a non-junior, full-sized Sodbuster (4 5/8" closed) with a longer blade. Might that interest (and be available) to you?As I have read the slim term is mostly about the handle not the blade shape or thickness nore widness. If it's so that wouldn't be a problem for me as I liked the Boker UT slim handle.
The blade is my concern. I am not a huge fan (now) of the narrow width (broad) shape (edge to swill) of medium workman stockman and mini trapper as it is as half of victorinox. I like broader blades.
SodBuster jr have broader blade but it is almost as short as Victorinox is.
The problem is that in Poland we don't have too many of trappers especially in good price as this one is...
If it were mine, I might check to see if it looks like it's stabilized. If a small drop of water beads up and rolls off, that would suggest it could be stabilized, in which case it probably needs little else to protect it. If the water soaks in, then maybe just a minimal, thin coat of oil or wax might do. Also, over time, if the wood looks like it's picking up & holding dirt from handling & such, that suggests it's not stabilized or otherwise treated with varnish or polyurethane. Stabilized handles are otherwise very resistant to retaining dirt from handling. Assuming Case made this, I think they've been pretty consistent about stabilizing their wood handles, at least in the modern era (1980s or later in particular).This one came today, no bladeplay like it was in the previous one which I replaced.
It's rock solid, beauty, curly maple wood handle. I like the size of it as it's shorter than Boker Urban Trapper but longer than mini trapper or stockman.
After sometime I will write more about it.
Question: should I use some oil on this wooden handle or leave it like this?
