I have my DIY heat treat oven working at last so ready to start heat treating my stainless CPM 154 blades. I have everything to do plate quenching but before I dive in thought I should ask for some advice. Everything I have read here indicates that this is the preferred method but I have two concerns:
It seems that if I pre-grind my bevels before heat treat (like I did before sending to Peter's for last few) I will be quenching the spine and flats but not as effectively cooling the ground edge? Will this affect the hardness of the cutting edge? I know the hardness tester works on the flat surfaces so may not measure this?
On my last O1 blade (oil quench), I did a tapered tang and really like the balance I got, but won't this make it even less effective for plate quenching? It seems that I will only have contact with a small part of the blade- ricasso- but the rest will cool more slowly? I am planning to use the stainless foil wrap of course.
I am sure everyone has resolved this to work well based on the popularity of plate quenching but would appreciate any guidance.
Thanks,
Stuart
Thanks,
Stuart
