- Aug 14, 2018
I've been grinding away on my first stock removal knife, using 1095 steel, and having a very good time working on the blade. Y'all have been a great resource in learning the tips and tricks of the trade so far, but I find myself at the point of needing direct advice as opposed to just reading the archives.
After I got the blade into the shape I was envisioning and the surface finish I thought appropriate, I had allowed the edge to thin too much. Understanding that this makes blade warpage a risk during heat treating, I gave the blade a run of normalization (3 slow runs up to about 1425F w/ air cool) as some have described here and then heat treated it (slow run up to non-magnetic plus a little time, then quenched in canola).
Well, in any project something must go awry, and in my case it was the edge. You can see in the photo that the overly thin blade edge went wavy. The blade itself didn't warp or twist, just the edge, and only about 0.25 mm from the blade centerline, with the distortions rising from the edge only about 0.5 mm towards the spine.
What opinions do y'all have about how to approach this problem? The way this newbie thinks, there are two approaches:
- File the distortions out, i.e. shortening the blade height, and then putting in the planned secondary bevel.
- Filing/stoning in a tall secondary bevel to remove the distortions.
Regardless, being my first attempt, I'm going to finish this blade even if it's such a bag of crap that I keep it remind myself of the learning process.
Thanks,
Chris Horner
Thanks,
Chris Horner
