The top blade is too "stiff". It needs some slight curve to the spine, or a little drop at the tip.
The second is better. Both need the edge curve refined a bit.
How do you plan on drilling the holes in the sawzxall blades?
I know you are having fun grinding down sawz-all blades and making these, but you will be amazed at the improvement in quality and looks that you will get when you gets some real blade steel and make a knife with a file and sandpaper...and harden it. The sawzall blades are not likely hard except the actual teeth tips.
For these two designs, I fixed the second one (pictures when I get home). You were right, the blade was "upside-down." As for the first, I understand what you mean by stiff. I think it might need a small upwards curve. I will take out the step at the handle. I am modeling it a bit on this style, just smaller.
I think I have changed my mind on the steel. I am just finishing my first one from a sawzall blade and even though it was cheap, it took twice as long as it should have as I had to fight the steel. The teeth side is hard, but super brittle. The spine side is springy and seems to hold an edge about half as well as my store-bought knives.
I went through 7 hacksaw blades just to cut out a 4 inch (overall length) knife. I didnt end up being able to drill holes in the steel, so I did a work-around by cutting a line in the steel that was as thick as the pins. This will hold the scales top-bottom and rotationally, but the scales could theoretically slide forward and back. Im not worried about it since it is so tiny, epoxied, and is just for home-office use.
Here is the first one almost done. I have learned a lot from it and am going to start ordering steel for the two knives in this thread so I can do it right. I am happy with this one so far, but I will be happier using better steel I think. I was thinking of ordering 1084 since I have read on here that it is able to DIY heat-treat.
Thank you guys for all the continued advice, I really value getting the input for some more experienced people.
