- Jan 16, 2006
I just had the opportunity to get a hold of some AEB-L steel and make a knife and heat treat it. I also did some cutting tests on rope with the same technique and method out lined in the previous series of tests Cutting tests on 4 knife steels. This post is under the Reviews and Testing section of this forum and rather than re-post it here pls see that for detail on test method. The stock finished at .080 wide at the blade spine behind the finger guard. It is flat ground to a .006 thickness at the edge. This knife is a 9 inch fillet with Micarta handle. Rockwell hardness is 60. I did the cutting test twice and the average was 95 cuts. Here are the results of the previous tests with AEB-L added to the list.
Results:
Cuts RC hardness
CPM S 30V 210 61
CPM 154 150 62
154 CM 110 61
AEB-L 95 60
12C 27 90 59
Here is the heat treating recipe I used for the AEB-L: Turco was used for oxidation and de-carb protection
Insert blade at 1500 furnace temperature
Ramp to 1980 and hold for 20 minutes
Air quench in front of a fan
Subzero in LN2 for 2 hours. Hardness out of the LN2 was 62
Temper twice at 400 and a third time after final grind and finish at 375. final hardness is 60
I found the AEB-L to be a little gummy to grind before heat treat but very easy after heat treat. If finishes very nice on a 400 grit belt.
It is easy to sharpen and in fact I was able to restore the cutting edge just by back stropping on loaded leather. This steel can get very sharp and it is easy to get it to shaving quality quickly. Toughness seems to be very good. In fact I continued to cut past the 20 lb limit on the second test and wrinkled the edge at about 30 lbs.
Phil
Results:
Cuts RC hardness
CPM S 30V 210 61
CPM 154 150 62
154 CM 110 61
AEB-L 95 60
12C 27 90 59
Phil
