Stromberg Knives
strombergknives.com
- Jan 3, 2015
That’s how I understand it also.So if I read that correctly it says pop it in the oven and start the timer for the time listed next to the thickness.
Soak time will vary from furnace to furnace.
Hoss
So speaking about rebound would it not be better to do a dry run with out any steel in the oven to see what the rebound is without the cold steel in the oven then add that time to the time for the knife. This way you know how long it takes to get back to where the oven should be with a cold knife in the oven. It's my understanding that thy take into account the time it takes for the steel to heat up and that's included in the total time. With thin blades thy heat rather quick and could be close to temp by the time the oven is done rebounding which then means if you then held the required time you would in fact soak for longer then thy say.
Some ovens have enough mass, enough output, enough pre-heat, to make rebound nearly inconsequential
Well whole inside of oven is refractory bricks so there is nothing to hold temp .I read that someone use to put inside THICK piece of steel to keep temp high when open/close door .. What if say floor and ceiling of oven have say 1/2 inch thermo-accumulation bricks / I don t know right word for that kind of bricks/ . Oven will reach the temperature more slowly but will have more constant temp. in open/close ... Sorry for off-topic![]()
