- Oct 19, 2011
Ok, so this is what my heat treat looked like. Wrapped in foil with paper chip inside. Heat to 1560˚ in an Evenheat oven with a 5 minute hold. Ramp up to 1990˚ with a 15 minute soak. Plate quench between two pieces of 2" X 4" X 18" 6061 aluminum (or aluminium for you blokes across the pond). I stood on top of the plates as the blade cooled for 15 minutes. Yes, I know, way more time than necessary. Then open the foil pouch and into the dry ice/denatured alcohol sub-zero bath for 70 minutes. I know, more time than needed but I was watching a program. I let the blade come up to ambient temperature then into a preheated 325˚ oven, verified with a rack-type thermometer. It has been in for 2 hours. I am getting ready to go in for the second temper but I want to make sure I get close to my target of 61.5 Rc. Should my second temper be hotter? If so, what is your suggestion? It looks like, according to AKS chart, 61.5 should be around 375˚ with the sub-zero step. Any reason not to go with 375˚ for my next temper? This blade will be a chef knife. Can I safely go harder than 61.5Rc?
