I don't mean to derail this thread. If this is too far adrift I'll delete.
I have an AEB-L blade with issues also though not quite the same. On mine you can see a stripe down the center which appears to be a different color. The bevels are dead flat which rules out differing angles of reflection. The center seems to accept grinding different than the edges. The scratches disappear from the center long before the edges. I've been up and down the grit progression several times between 220 and X16. The higher the grit the more the line shows. It resembles a temper line. Heat by Bos, hardness test at 1/4" from the edge @ Rc 61.5, ground post heat treat. One of 4 blanks cut from the same bar of Aldo's steel. The others do not show this. Talking to Paul at Bos, the blanks are side by side on a belt for the whole heat treatment. Weird.
