A weed burner and a few firebricks will barely get O-1 steel hot enough for hardening ( as you found out). It won't keep it at the right temp long enough to harden it properly at all.
Using 1084 steel, the torch you have, a dozen or so soft firebricks ( you don't want the hard ones), a magnet, and 120F canola oil, you should be able to get a reasonably good HT.
Stack the bricks in a long tunnel with the torch coming in from the back corner at an angle. About a 3"X3"X12" tunnel interior is what you want. The flame should sort of swirl around the tunnel walls from back to front. You have to play with how the torch sits at the entry point. Sometimes it is close to the hole, and sometimes it is just barely in the hole at the bricks.
You can just stack the bricks, or make a more permanent arrangement by jointing the bricks with fireplace cement ( hardware store) and pinning them together with long nails or pieces of stiff wire. A few twists of bailing wire will help keep it all together for a while.
Run the torch for a few minutes to heat up the bricks and then put in your blade. Using tongs or long handled pliers from Harbor Freight ( see below), move the blade in and out and turn it constantly. Stick the magnet ( see below) to something near the "forge" so it will be handy when needed. As the blade gets red, pull it out and touch it to the magnet. It should stick at plain red, and then as the blade gets a bit hotter and redder, it will suddenly stop sticking to the magnet. This is about 1350F. You want to make the blade around 100F hotter than that, so heat about one shade of red more, make sure the whole blade is evenly red....but the edge is what you want to pay attention to....Don't let the edge get super bright cherry red! ( that's too hot). Once the blade ( or at least the edge area) is the right temperature, immediately quench in at least one gallon of 120F canola oil. Plunge straight in like you were stabbing the oil. Move up and down, but not from side to side. Keep the blade in the oil for at least one minute. Take out and check with a file to see that the edge is hard. If it is, gently wash the blade with soap and water and then place in the kitchen oven at 400F to temper for two hours. Pull out and cool off in running water. Put back in the oven for a second two hour temper. Do these tempers as soon after the quench as possible.
BTW - You heat the oil before you start by using a piece of metal rod ( rebar or whatever) in the forge and plunging it in and stirring the oil. Once the oil is about 125F, you can go on to heating the blade. A cheap HF digital thermometer ( see below) will work for checking the oil temp ( Before you ask, the HF laser thermometers are useless for checking the hot blade temp).
This will give you a good hardened and tempered blade that will cut and last well.
Here are some good beginners things from HF:
http://www.harborfreight.com/16-inch-long-reach-pliers-set-38598.html
http://www.harborfreight.com/15-inch-long-reach-locking-pliers-97609.html
Magnet:
http://www.harborfreight.com/4-3-4-quarter-inch-multipurpose-magnet-holder-1938.html
Thermometer:
http://www.harborfreight.com/hand-tools/thermometers/instant-read-digital-thermometer-95382.html
