TyFrameLock
BANNED
- Nov 26, 2009
AG Russell Acies
I Like:
-Titanium Frame Lock
-Lock Stop
-Deep pocket carry clip
-Wide profiled blade
-Easy dis/reassembly and cleaning
-Perfect styled thumbstud
-ZDP-189 Steel
*Razor sharp
I Don't Like:
-ZDP-189 Steel
*Chips easily with 18* 20* 25* 30* bevels
-Finish on the blade
*Scratches easily
-Unfinished inside of scales and lockbar
*I would expect higher level of finish on a $375 knife
-Shiny finish on clip
*Sandblasted it and now it's perfect
-Clip doesn't slide into pocket very nice
*Countersunk screws into clip
*Ramped the end to better slide in
*Now it's perfect
After about 2 months of use I can't put this knife down. The ergos are great, the blade shape is nice and the full flat grind works great. The tolerances are pretty decent with no blade play at all, and a close to centered blade. Opens and closes very quickly without hesistation.
The addition of a titanium framelock with lock stop and a perfectly shaped thumbstud make this thing a close to perfect grail knife for me.
The
The zdp steel is where it falls off course as a perfect knife IMO. It's just a little bit too hard for an EDC - Hard use knife.
As an electrican I am always stripping wires and when the zdp come in contact with copper ( a soft metal) it chips, and it chips and it chips...let down. I first started with the stock sharpening/bevel which measured around 22* on the edgepro. I then decided to ramp it down to 25* and it still chipped...ramped it down to 30* and it still chipped.
I then decided just to see what kind of sharpness I could get out of it and ramped it up to 18* it still chipped of course, but the thing is that it didn't chip any worse than at 30* which is kind of surprising. So I might as well keep it at a sharp angle and take advantage of the cutting ability. But it just won't do for a work knife, that is were the softer s30v sebenza takes over.
Alot of people compare it to a sebenza, and with first hand experience they are two completely different animals.
In Conclusion:
If it was offered with a different steel such as s90v (which i'm going to get a custom s90v blade made for it since I can't put it down) it would be a hard knife to beat.
I hate to say it but at this price point ($375) I think it should have a higher level of finish and a more hard use type of steel.
As shipped I think it should be closer to a $300.
But other than that I think this is a very very nice knife and if you don't use the zdp too hard it's a great knife.
I can't put it down, when I reach to grab either my sebenza or the acies I keep picking up the acies.
I Like:
-Lock Stop
-ZDP-189 Steel
*Razor sharp
I Don't Like:
-ZDP-189 Steel
*Scratches easily
*Now it's perfect
The
In Conclusion:
