Agitating quench.
I saw Fred Rowe's post about his circulating quench setup and I got an idea. Would it be feasible to use one of those long drill-powered paint-stirrer things to agitate a quenchant on a budget? Obviously there are problematic details, such as having high enough sides on the container to avoid flaming oil spills and etc. but the concept seems sound to me. Are there any obvious deficiencies I'm overlooking?
"Mete" talked about doing a whirlpool agitation either here or on KN or SFI (under "Robert C."). Sounded like quenching near the wall with edge into the flow was what he did or thought would work well.
Sorry... I can't find the link to it.
Mike
ALWAYS agitate when quenching , either by moving the blade or using a mechanical stirrer or pump.You must break up the vapor barrier !
Here is my setup.
I took a 12 gallon electric water heater (a 5-6 gallon will work,too) and removed the top shell. I cut out the top to make a tank of it. The in and out fittings were on the side, so I hooked a simple 12VDC fuel pump ( auto parts store) in the loop. I made a copper J-tube to stick in the bottom ( it just plugs into the bottom port from the inside) that diverts the flow directly up from the center. I added a transmission cooler radiator and a 12VDC cooling fan (auto parts store) to the loop, too. The fan had a temperature relay control that turns it on and off. With the electric heater set at 130F and the cooling fan set at 140F the tank maintains a pretty even temperature when quenching multiple blades. It holds 10 gallons of quench oil. I use the old top shell as a lid. The 5-6 gallon units will work the same with 5 gallons of oil.
The recirculation is a gentle flow, but helps carry away the vapor jacket and increases convection.It seems right for the cooling rate through the radiator,too. A bigger pump could be used if you wanted more agitation, but for my uses, the smaller pump seems to work well.
Stacy
