varispeed exposed sanding disk to flatten stuff out
Changing PSA disk takes seconds, it flattens giant size
areas to absolute flat etc etc etc.
But not many of us can justify the expense or find the
space required to host such a monster.
So ... how about making it as an attachment to yer KMG/Bader
grinder ? $60 in parts and u got yerself an attachment that
clamps right onto the arm of the grinder. Seconds to put on or
to remove
http://img174.imageshack.us/img174/212/dsc0001wn4.jpg
Parts:
- 2 pillow block bearings, 3/4" ID in my case
- some HRS to make a plate (~5x5") to put these onto
- a 3/4 shaft, reduced @ working end to accept whatever hole
your disk has
- $5 die-cast V pulley from yer favorite supplier. I turned it down to where
the V turned into a flat
- 3-rib belt in proper length, used inside-out
- 12" disk I bought @ Grizz - it is a spare part for one of their grinders.
9" is a more popular size, as sanding paper is so cheap. But, you can easily
switch between disks of different size, so you can have your cake and eat it, too
to remove
Parts:
your disk has
