Bill DeShivs
- Jun 6, 2000
Something is very wrong with your window!
OMG.... this couldn't be more wrong. You absolutely have to worry about dust settling after you grind. Steel can be airborne for a LONG time.... especially the dust that is the most dangerous! The simple act of walking kicks up fine particulate. Opening a big garage door just blows it into corners, away from proper disposal.If you work in a shop with garage doors or the like, I don't find air purification all that useful. I wear a respirator in most dust producing tasks, so I am not worried about breathing it in while I make it. I generally will pop the garage doors for a few minutes (I live somewhere with some wind and I have doors on both sides of the garage) to evacuate the air after a task that produces dust. When grinding knives, you really only neet to worry about the abrasives and some of the handle materials. The steel itself wont be airborne for more than a minute or two.
For knife work, there are a bunch of options but a decent bucket style cyclonic filter with a water filled bucket underneath the separator and a collection hood beneath the platen is probably the best way to go. Only thing that perhaps would reduce the need for the respirator would be a coolmist system in conjunction with the seperator, but I would still wear one to be safe.
Either way, you dont really have to worry about the dust on the floor, the particles are all far heavier than air, and settle out. Just sweep up regularly and you are fine. The dust collection is for convenience and cleanliness more than safety.
I'm sorry for overreacting but HOLY SMOKES that is some bad advice. I fear for your lungs, dude. Respirator or not.
Air movement is your enemy with dust management. Fans, brooms, airguns are dangerous tools to battle harmful particulates.
A collector hood under the platen is picking up mostly the big stuff. The fine particulate is swept away with the current of the moving belt. If your intention is to capture the dust that does the most harm, you need a shroud around your grinder with a semi-enclosed loop removal system, either gathered by a localized collector or exhausted out of the room.
Clean up with a shop-vac, not a broom and pan, wipe down tops of benches and machines with a damp/oiled cloth. Air filters are okay but make sure they don't kick around dust as they work. Maybe have them on a timer after you leave. Wipe all surfaces when you return to the shop and everything has settled.
This is an old thread I made. My current system is improved but this gives you the idea.
https://www.bladeforums.com/threads/i-made-a-dust-evacuation-system-for-my-grinder.1157981/
I did have someone test the air in my shop. I'm not sure what they used but it gave two readings... large and fine particulate ... <2.5 micron and >2.5 micron. They were contracted to test the newly renovated Opera House in town.... he was a knife guy... lol
The readings in the center of the shop were 109 and 15
5 minutes of my system on it went to 225 and 22 ... then dropped down to 125 and 19
after 20 minutes of grinding it read 520 and 33
10 minutes after I stopped grinding(system still on) it was 220 and 21
we turned off the filter and started the grinder... 800 and 45
I ground for 5 minutes... 5200 and 270!
left for 10 minutes and came back in... 2500 and 180!
swept the floor... 2900 and 212!
Funny enough, when we went outside, it read over 3500 and 400!!! But the guy reminded me that it was now reading organic materials like pollen, smoke, etc...
I don't really know how to read or compare those numbers, other than the system significantly dropped them in my shop. The guy had equipment that measured to a higher accuracy and separated for mold, dust and a bunch of other stuff... even gases... but it was expensive company machinery and we were off the job site. The meter he used was about the size of a 6-pack of beer and he could not hold it to do the reading. It had a fan intake and had to be stationary.
Maybe if you are only in the shop a couple times a week the accumulative damage won't show itself. I am in my shop 8-14hrs a day. If I was as nonchalant about dust as you seem to be, i'd be in trouble by now. I personally know four people with respiratory issues directly due to metal/epoxy dust, one maker who has had part of his lung removed and a boat builder acquaintance who resides 6ft under from long term exposure to epoxy and wood dust.There is nothing about organic materials that make them less dangerous than inorganics. Infact, the reverse can be true. Air evacuation is not your enemy against airborne particulates. It can kick up dust, and that is why you should sweep/vacuum. Look, reasonable precautions and dust collection are a good idea, but we aren't talking about sarin. Just wear a respirator with the proper filter and clean up and you will be fine. I am not saying that you can't or shouldn't run more complex dust collection, but the idea that you are incurring a meaningful level of risk if you don't have crazy hooded dust collection and realtime filtration is sensationalist and unsubstantiated. Our fine particle crystalline silica concentrations are not nearly high enough to exceed the max safe levels while wearing a half mask. Unless you are burning kaowool or something silly, and perhaps not then.
Cleanliness, a good respirator, and scheduled filter swaps are all you need. Make sure your filters are appropriate for what you are dealing with. All the rest are nice to have, can add convenience, and may be a good idea if you show allergic reactions or the like. But the idea that you need thousands in dust collection or your shop time is hastning a grizzly death isn't supported.
I do understand that you are wearing a half mask... that is really good. But unless you keep it on after you grind or clean up, you aren't protecting yourself from the dust you don't see. As someone pointed out, it can stay airborne for days and get kicked up when you walk past benches and turn on machines.
The OP wanted to know what he could do to minimize the risks for he and his wife. Unless she is wearing a half mask as well, I would think that his needs go beyond PPE and step into air quality management. But again... how often is the exposure? Can he work one night, let it rest and carefully clean the next morning? Sure.
