Wikipedia gives some more details about the axe used after the 1995 plane crash in Georgia:
"Despite a dislocated shoulder, First Officer Warmerdam used the cockpit fire axe to cut through the thick cockpit glass. David McCorkell, a surviving passenger, later assisted by pulling the axe out of the cockpit through the hole Warmerdam had created and struck the glass from the outside in order to increase the size of the hole and help Warmerdam escape... The emergency crews successfully pulled Warmerdam out of the aircraft."
He wanted out. Right tool, right time, right context.
In Ottawa back in the 1960s National Research Council of Canada built a chicken gun to simulate bird strikes on aircraft. The very long barrelled compressed air cannon launched specific weight chickens at close to the speed of sound. Forward windscreen glass was discovered to be particularly vulnerable and manufacturers have had to beef these up ever since. The primary reason SWAT forces maintain 50 BMG scoped rifles now is they're one of the very few rounds that can reliably penetrate modern aircraft cockpit glass.They should not only require the proper equipment but they should require egress training. I can see why one would THINK the glass was the fastest route.........
Just another example of how knowledge and a little hands on life experience would allow one to work smarter. Instead of flailing about like a buffoon. It is amazing that when they decided they needed an ax to escape.......and that a small amount of people would have access.........they did not also come to the conclusion they might need a brief or two.You'd want to be fueled by a lot of adrenaline when figuring on chopping out airliner front glass with a hatchet!
Yeah, there really is not much room in those puppies. The recommended cut out zones for rescue are usually overhead. 11 and 1 and whatnot. There is not much room for anything that might give you enough humph to bust out. Sounds like a more coordinated effort to make sure that window can be opened with multiple failsafes perhaps multiple sliding windows and prybars........The report said that the sliding side window was jammed by the crash impact, and if the axe had a prybar function, then perhaps the first officer would have been able to pry it open. During the investigation of the crash, prybars were successfully used to unjam and open the sliding window.
Steve, you come up with the most interesting topics. Glad your here. DM
