- Aug 10, 2013
hello fellow knife lovers
Today I have some airsoft gear to trade for some knives
I have a KJW Full Metal M1911 Tactical and a Matrix AIM Lipoly Ready 8mm Gearbox M4 Carbine.
The M1911 was only used in acouple games. Has some lint on it from the case, but besides that really only shows wear on the magazine. It'll come with 1 magazine.
The M4 was used only for 1 full day at an airsoft park. I had it perfectly "Zeroed" to my scope and even tho it isnt a "high end" rifle it easily was outshooting my friends higher end guns. I mounted rails on it as well as an Israeli sling and attachments( as you can see in the photos) It will come with the rails I added, sling, 2 hi cap magazines, and 1 Intellect 9.6V Small Type 1600mAh Airsoft Battery Pack. SCOPE IS NOT INCLUDED IN THE TRADE
If you have any questions let me know
Im currently wanting a "gentleman's knife" so anything classy like would likely peak my interest, but open to all offers
I have a link to my photobucket with some pics. If you want more just let me know
http://s33.photobucket.com/user/knifeandgun/media/IMG_0661_zpslvepkshq.jpg.html?sort=3&o=0
-Sebastian
here are some specs
M1911 Specs:
System: Gas Blow Back
Muzzle Velocity: 300 to 330fps
Magazine Capacity: 30+1
Gas Type: Green Gas / Red Gas / Propane
Features:
TanioKoba Grip
Improved Trigger
Metal Slide and Frame
Forward Cocking Serrations
Ambidextrous Slide Safety
Metal Barrel and Guide Rod
Functional Grip Safety w/ Beaver Tail
Under Barrel Rail for Flashlight
Improved Iron Sights
M4 specs:
External Features:
Light weight Nylon ABS Receiver w/ "Special Forces" Logo.
Full Automatic Select Fire.
Flip Open Mock Dust Cover simulating real M4. (Pulling the charging handle will open the real dust cover and flip open the mock if it was closed.) Mock dust cover is designed to stay open most of the time simulating real AR.
Flat top weaver receiver ready for any scopes and optics.
Full Metal Convertible Barrel.
Full Metal Front & Rear Sight.
Ready for any RIS / Conversion Kits.
6 Position Retractable LE Stock.
Metal convertible outer barrel (could be sealed tight for importation purpose)
Adjustable Hopup.
Internal Features:
Li-Poly Ready (for experienced players).
High ROF feeding for Lipoly (Tested with 11.1V 1350 mah)
High Speed Piston with Metal Teeth.
"Matrix" Fully Upgradable Super Gearbox with superb Air Seal.
Steel RPM Gear sets.
Steel 8mm Metal Bushing Gearbox.
Torque up Motor.
6.04mm tight bore barrel: Installed.
Torque Up Motor: Installed.
- Railed upper receiver with detachable carrying handle.
- Adjustable Hopup.
Magazine Capacity: 360 Round AIM Top metal hi-cap included. (Use all M4/M16 series AEG Magazine).
Best Mags: Hi-CAP: JG, Matrix and compatible. Mid-CAP: MAG.
Muzzle Velocity: 320~350 FPS
Thread Direction: 14mm negative.
Gearbox: 8mm Full Customizable Matrix Ver.2 AEG Gearbox.
Motor: Long Type
Fire Modes: Full / Semi / Safety select fire.
Manufacture: AIM (Taiwan) Matrix (USA)
-Sebastian
here are some specs
M1911 Specs:
Features:
TanioKoba Grip
Improved Trigger
M4 specs:
External Features:
Adjustable Hopup.
Internal Features:
Torque up Motor.
- Adjustable Hopup.
Motor: Long Type
