Silas said:I have really been wondering if you could make a sheath like your talking about but use G10. Cut a long strip in half and then use a router to carve out the channel. Then figure out a way to put them back together, which I really don't think would be too hard, and shape them into a sheath.
Would G10 work? Is it expensive? Can you get it in a size big enough for this project?
wuyeah said:I gave up finding those custom wood case!!! Yet I have used my limited knowledge with a bit creativity. A REAL REAL Ghetto sheath.
Cue stick hard shell protective case!!
howz that guys!! i cut open the top zipper cap off. The protective hard shell cue case left with protective foam. With AK is easy, you just push in there. I will cut through the foam. Here you go. You got a sheath, it is also come with carrying belt. haha, I kind of like it. I kind of think, it is better than anything!! the foam protects the blade, you won't even creat scratch mark!
For those who don't have the lot of money to buy a sheath at the same time want to protect a beautiful AK, I think it is good way to go for it. it looks some what semi japanese like. the best thing is, no problem carry around EXCEPT, the law will stop you.
Give a Try.:thumbup:
