Shirogorov/Sinkevich Kami
I never win lotteries like this, except I did this time.
BNIB, came in yesterday and it’s not for me, although it’s perfect in every way: Fit, finish, mirror edge, clip/lanyard hole detail, milling inside and out, you get the picture. I’d rather see someone own this that can appreciate it more.
SPECIFICATIONS
$1575 PayPal G&S preferred
*No trades please, unless a Hawk Deadlock.*
Spyderco C81GPWC2 Para Military 2 - CPM-S30V Satin Finish Plain Edge Wharncliffe Blade - Black G-10 Handle - CUTLERY SHOPPE EXCLUSIVE
** 900 PIECE EXCLUSIVE ORDER **
This brand new blade shape is exclusive to Cutlery Shoppe for the Para Military 2 platform, and this is the "launch" knife and the first of many to come.
The blade steel of this new wharncliffe PM2 is the proven CPM-S30V blade steel. This special exclusive Para Military 2 Wharncliffe is made with pride in Spyderco's Golden, Colorado factory.
Spyderco PM2 wharncliffe. BNIB. I got 2 in the drop a couple of weeks ago, sold 1, realize I don’t like these a whole lot. PayPal G&S $170 preferred *no trades please*
Spyderco C223GPORBL Para 3 - 2.95" Satin Finish CPM-REX45 Blade - Orange & Blue G-10 Handle - CUTLERY SHOPPE EXCLUSIVE
** LIMITED 600 PIECE PRODUCTION RUN - THERE WILL BE NO MORE **
Cutlery Shoppe has the exclusive with Spyderco on these dual color variants.
*no trades please *
SPECIFICATIONS
- 3.50″ Stonewashed S110V blade with Mirrored flats with complex and asymmetric blade grind
- 8.00″ overall length
- Weighs 3.4 ounces
- Titanium frame-lock handle scales with milling pattern
- Steel insert in lock-bar that also functions as an over-travel stop
- Jimping on the spine of the blade
- Lanyard hole that also functions as a reversible pocket clip
- Runs on Multi Row Bearing System
- Titanium pocket clip / lanyard hole also functions as stand off
- Milled pockets on inside of both handle scales for weight reduction
- Number etched on inside of front scale out of 300
- Blue anodized Titanium pivot
- Blue anodized Titanium hardware
- Tip-up Titanium pocket clip with bead-blast finish
- Limited to 300 pieces worldwide. Each knife is individually numbered
Specs:- Category End Use: EDC/Collector
- Blade Steel: CPM-S30V
- Blade Grind: FFG (full flat grind)
- Blade Length: 3.44" (87 mm)
- Length Open: 8.28" (210 mm)
- Length Closed: 4.81" (122 mm)
- Blade Thickness: .141" (3.5 mm)
- Hole Diameter: .5" (13 mm)
- Lock Type: Compression
- Handle Material: Black G-10
- Tip Carry: Tip-Up/Down
- Clip Position: Four Way
- Weight: 3.9 oz. (111 g)
- Made In: U.S.A.
- Blade Steel: CPM-REX45
- Blade Length: 2.95" (75 mm)
- Length Open: 7.24" (184 mm)
- Length Closed: 4.29" (109 mm)
- Blade Thickness: .145" (3.8 mm)
- Handle Material: Orange & Blue G-10
- Weight: 3.4 oz. (96 g)
- Made In: U.S.A.
*no trades please *
