I've only seen them numbered through 100 even if they produce more and they typically do use a three digit number. I didn't see where they said they would be numbering these through 500.
It says so on the web page and OP.
That's cause this IS a limited run of 500 . All the knives in this LE will be numbered from 001 to 500. Example on the blade the numbers are engraved 001/500,002/500 , and right on up to 500 . I do believe I have not seen this type of run from them before eather as they have only done numbers for the first 100. But this time it is 1- 500 . Hope this clears it up for you 🤙 I never saw what Daniel saw on this particular Knife. All 500 will be numbered from what I read and the start of this thread clearly says that.I don't see it. I only see that it's a Limited Edition 500 total.
Daniel indicated he had one numbered under 100 and mentioned they took that information off the site after the first 100 were sold. That seems to be in line with what C&C has done in the past. I'll be interested to find out now if there is a 101 through 500 on the blade. I guess we will find out shortly. Or I'll just buy one and find out myself.
Your welcome 😊Sounds good and makes perfect sense if they are putting the whole thing on the blade like you said i.e. 001/500. Thanks. :thumbup:
