This one is set up the same way-maybe 4" of unedged choil, but still tapered enough to use to split. I thought they were all like that, so my old one's the same way.Very nice! One of you guys should make a Duku Chandong style Parang (also known as Ray Mears style). In my opinion those are the most useful kind of Parang. Only half of the "blade" is actually a blade, the lower half is totally square and meant to be used as a grip. This "extended choil", for lack of a better term, is long enough to fit your entire hand. When you hold a Parang by the wood hilt it's a weight-forward chopper, but when you hold it by the extended choil, the weight of the blade and the hilt balance each other out. So you're left with a 6 inch balanced blade you can do fine carving work with. Natives who use this kind of Parang use it for every kind of task both large and small.
Do you have a picture of the carving knives? I've never seen one. In the videos you see on YouTube of the native jungle folk over there, they seem to be using their parangs for every task.
