ALL BELOW ARE SOLD
1) Milkyspit M1 Illuminator [Sold on another forum] $170 $175 $180
Tale of the Tape:
Cool white tint, 3-mode ShiningBeam driver with memory. Has diffusion film applied on outside of lens. Head can be opened so for those inclined an emitter swap may be possible, though I don't know how the pill would come out. In very good to excellent condition. Tape will be included but is no longer on light.
2) DS FiRE-FLY III [Sold on another forum] $60 $65 $67 $70
This is a catch and release as some more important matters came up. Unknown cool white emitter with a slight lean towards cool-neutral. Frosted Optic for a nice flood. Works on primary CR123a's or RCR123's (brightness increases nicely on RCR). FLuPIC firmware, version unknown. UI is as follows: Low Brightness Level (User Settable), High Brightness Level, Set User Brightness, Strobe.
3) Peu Bare Al Neoca BL CR2 [Sold on another forum] $40 $45 $47 $50 $53 $55 $57 $60 $62
Same as above, this is a catch and release due to said reasons. 2-stage progressive twisty. Cool white emitter that has a bubble on it. Doesn't seem to affect the beam too much (beam shot included). There is something on the reflector also - top-down view at the 12 O'clock mark. A blast of compressed air didn't budge it.
4) Muyshondt Black Aeon [Sold to VVilliam] $125
This is a user as is evidenced by the photos. Body is is pretty good condition, most wear is on head and a little under the split ring. Twist action is very smooth. Tint is cool white but leans a bit towards yellow. Nice throw for a light this size.
5) Mattaus Hyperion P60 module [Sold on another forum] $60 $70 $75 $80 $85 $90 $95 $100
Single XM-L2 Neutral White T6 3A @3A. This will not include an outer spring.
7) EagleTac D25Cvn Limited Edition Ti XP-E2 V2 [Sold on another forum] $60 $65 $70
Uncarried, only tested.Modified by Wayne (vinhnguyen54). Dedomed cool white emitter (now in the neutral realm) and throws like a champ for it's size. Full disclosure: There are two artifacts visible on a while wall due to the dedoming - in actual use this cannot be noticed; pocket clip arrived slightly raised at the bottom and slightly pitted at the bend (see photo). Comes with box, holster, and all accessories.
8) EagleTac D25Cvn Limited Edition Ti XP-G2 V2 [Sold on another forum] $60 $65 $70
(I had purchased 2 XP-G2 versions) D25Cvn Ti V2 XP-G2 6500k Dedome + circuitry improvement (modified by vinhnguyen54). Has seen some light use in home and kept in case, excellent condition. Dedomed cool white emitter (now in the neutral realm). Doesn't throw as far as the XP-E2 version, but is no slouch in that area and brighter overall. Comes with box, holster, and all accessories.
Tale of the Tape:
CreeXML-T6C(304A1K) DCFix
McR17xrCut CustFabAlumSink
ShiningBeam3x(80/440/1400)
538 lumens on 1 x IMR16340
