Alternative Drive Wheel Recommendations
I am finishing up a DIY 72" grinder and need some advice on a drive wheel. I know that I should probably just order one from Beaumont Metals but I am running out of money and need a cheap alternative. Anyone have any suggestions? I am using a 5/8 shaft (Which I ordered from Beaumont :D) which already has a 3/16 keyway. Thanks for any help.
In that case, I figure the drive wheels and the wheels in general are something you way want to bite the bullet and get quality. As nice as it would be to save a buck, they seem like some of the most crucial parts and also some of the hardest to do right without buying them premade. Just my opinion though.
Your probably right! I just thought that the drive wheels only purpose was to pull the belt along and was really not needed for tracking purposes, but I could be wrong. I guess I will just have to save my pennies and buy the drive wheel. I was reading the thread about someone using skateboard wheels for the contact wheels on the platen and tracking wheel. I did buy aluminum wheels for these but just thought I could skimp on the drive wheel. Thanks for your comments!!
A drive wheel needs to be balanced, or the grinder will shake itself apart. An aluminum wheel turned on a lathe will be the best choice. I know that $100 is a lot, but it is probably one of the two main precision items on a grinder ( the contact wheel being the other). USA Knifemakers has a good alternate for $95.
I am using a 1750rpm motor. I have a 5" pulley which will be on the other end of the shaft as the drive wheel. I am using a 2" pulley on my motor....what size drive wheel do you guys think I need to use?
I'm not good at figuring speeds...it sounds to me like it might run a little slow with a 4" wheel, but after having a variable speed unit for a while I don't find myself running at higher speeds much, so that might not be a bad thing. I currently have a 1750 rpm direct-drive motor with a 6" drive and variable speed, I rarely run much over 50% on the speed pot.
At any rate, you might find that it's cheaper to swap out one of your v-belt pullies to increase speed than to buy a 6" drive wheel.
Up on the drive wheel or the motor pulley, and/or down on the shaft pulley to increase speed. if your configuration allows you could just swap the v-belt pullies but with 2" and 5" that will be a big jump.
For now, If you are trying to save money, you can get by perfectly well with the two pulleys you already have. If you want a higher speed, just putter the 5" pulley on the motor, and the 2" pulley on the grinder drive shaft. I might be annoying switching them but you could do it for a short while and buy a proper drive wheel (which you need If you are using a shaft with keyways in order to keep the wheel drive wheel on the shaft and to keep it from spinning loose on it) and then buy two 3 or 4 step pulleys when you get more money. That my $0.02
-Paul
My YouTube Channel- www.youtube.com/Lsubslimed
(woops, I didn't see that Justin already posted that idea, sorry :D )
