You're also talking from the assumption that there is only 1 kinds of titanium and only 1 kind of aluminium.
Just like with steel there are multiple kinds of both alloys and they have different characteristics.
Titanium has a better strength to weight ratio. Strength to volume steel wins out.it is solft metal easy too remember
titanium is twice as strong as steel and half the weight, aluminum is half as strong but half the weight of steel
Al is soft therefore the coatings wear faster anodized - which is salt oxide. Hard ano helps.
New vapor deposit coatings such DLC if used will help 7075 is good alloy
Al like Ti gets an instant oxide coating
Ti is more flexible the steel and very difficult too weld, there are just 2 main alloys
alumium melts at about half that of steel 1400 f vs 2800 f processing approximate. Ti melts well over 3300 f
all can be powdered and made into explosives, Ti bottle rocket is very cool! Aluminum is used in flash powder, iron is used in black powder.
how will hold up just fine!!!!! for knive scale, terrible for blade.
I agree. While I prefer Titanium and CF as handle materials, I have no problem with Aluminum. But then I'm really not very hard on my knives and I haven't stressed any of these handle materials enough to find out how much they could take.My HTM Gunhammer is the same way, light weight even though it has these thick, chunky scales with no liners.
Blades aren't always made of steel. They make em outta ceramics, bronze, iron, and stone. (the last three are older methods)
I don't like the feel of aluminum scales. I love titanium scales. I like G10, CF, but don't like aluminum and wood scales.
ceramic blades are made of toughened zirconia which is the oxide, it a technical ceramic is fired until near liquid and has next too no pores. very few ceramics can meet the demands, this tech was developed for car engines until they found it degraded under use from guess what! water!
this has been made since the 80's and prices have fallen and fallen.
problem is the same while low porosity stops crack propagation, pores are smaller then the critical length too propagate.
hard too sharped, but can be wickedly sharp but the sharper the easier too crack, toughened mean it is resistant too tension but still not metal and does not bend. There is a solution but i am not going too discuss it and it has been researched along time.
Ceramic blades have a place, boker tried but replacing blades is expensive even at $200 a knife when that was a lot years ago.
While there are better choices price is the issue, grown Sapphire is very hard, born nitride is below diamond
Ceramic blade used carefully in the kitchen is interesting novelty but that is it. Non conduction and no sparks better then ti for that application. Complete resistant too salt, acid etc.
i had too add my 2 cents!
flint knives are interesting or glass knives made from volcanic glass, this was the most valuable item in south america pre-western invasion.
various glasses from nature are naturally non pourous due too condtions forced out gas and pressure made it toughened
i add 3 cents i guess
the ultimate knife blade is reverse what we all know, carbide is ceramic, reverse it, and solve the problem of the ultimate material but that problem has not been solved.
i have 20 year old project of making concrete as strong as technical ceramic - anyone have million dollars in seed money? email me!
if you shear off any folder's handle, regardless of material, you should not have been using a folder for that task. aluminum is fine, even if it isn't my favorite.
