Aluminum Fire Piston (impact style) FT
Feedback: +91 / =0 / -0
I have a machined aluminum fire piston that I'd like to trade for a new or slightly used Fenix L2D CE (LED flashlight). I'd also trade for a Fenix P2D or P3D. I have 2 of these left, I'd trade both of them for some blue class Benchmades, some Spydercos, and other knives (PE only please), just email me with options.
I don't know if this is considered a tool or gear, so I posted it in both trade forums.
I can custom make just about any shape/size/style of fire piston you would like.
I'd like to trade one of these strait up for a Fenix flashlight (L2D CE, P2D, or P3D).
I'd like to trade one for a Spyderco Cenotfante or Salt or a BM Griptilian.
I'd like to trade two for a ZDP caly, Caly 3, Lil' Temp, BM Activator+, Standard Spyderco Military, or S30V Griptilian.
I'd like to trade three (I have one on eBay I can pull) for a BM Rukus or Dejavoo, HK (14205 or 14210), Skirmish, or other Blue class BMs. Spyderco Military (BG-42 + CF), Manix, or other Spyderco G-10 knife.
I will also trade multiples for Ontario RATs, Ranger knives, Leathermans, Swisstools, quality fixed blades, quality folders, etc. Please email me with trade options.
Video of my fire piston:
http://s88.photobucket.com/albums/k168/michaelmcgo/?action=view&current=UsingAFirePiston.flv
>Machined 6061-T6 aircraft grade aluminum (Will never rot, and much stronger than wood).
>3/4" diameter wire brushed grip cylinder with 1/2" bore piston.
>Piston has a tinder retainer machined into its face.
>O-Ring seal provides 100% airtight seal to ignite tinder faster. Also keeps water out while stored.
>Tough materials and construction allows this fire piston to be ignited by striking against hard surfaces, instead of hurting your hands like many fire pistons require.
>Tinder can be stored in the large cylinder while the fire piston is not in use, the water tight seal will keep it dry.
>I machine these fire pistons myself in my machine shop in Grand Rapids, Michigan USA. Tolerances are held very tight for excellent compression and reliability. Each piston is lapped individually to it's mating cylinder for a precision fit. I test each fire piston and usually get ignition on the very first try.
>These fire pistons are of my own design, and are the result of many prototype models. I found that the method I use is more reliable than a two hand fire piston, and causes much less fatigue on the hands during practice and actual use.
Three still available, I would like to trade for quality folders and fixed blades of all kinds.
Sorry BJE. I already have most of the knives you offered. I'd like a HAK, but like you said, trade value doesn't match up.
