Aluminum Fire Pistons for Knives, Flashlights, Etc.
Feedback: +91 / =0 / -0
I would like to trade some fire pistons for knives. I am interested in folders or fixed as long as they are PE.
I like Benchmades a lot, especially axis locks.
I like Spyderco, Kershaw (looking for a composite blade Leek), etc.
Make me an offer...
Description of fire pistons:
Fire pistons were made centuries ago out of wood and provided natives with a primitive yet fast method of creating fire with limitless uses. A fire piston works on the same principles as a diesel engine in that compressed air creates intense heat. A bit of char cloth is placed in a small pocket on the end of the piston, and when the piston is compressed, this heats the char cloth to such an intense temperature that it glows red, allowing you to start a fire. I've been making these fire pistons for a few years, and have used them on many hiking trips. Char cloth can be made at home and carried with the fire piston, or some natural tinders can be used (certain mosses, fungi, and barks).
Details:
>Machined 6061-T6 aircraft grade aluminum (Will never rot, and much stronger than wood). Very robust design make this one tough fire starter.
>3/4" diameter wire brushed grip cylinder with precision reamed 1/2" bore piston. O-ring is standard 1/2" OD x 5/16" ID that can be inexpensively obtained at any hardware store should a replacement ever be needed.
>Piston has a tinder retainer machined into its face.
>Tinder can be stored in the large cylinder while the fire piston is not in use, the water tight seal will keep it dry.
>I machine these fire pistons myself in my machine shop in Grand Rapids, Michigan USA. They are machined by hand on a lathe, which is time consuming, but also guarantees the highest quality. Tolerances are held very tight for excellent compression and reliability. Each piston is individually mated to it's cylinder for a precision fit. I test each fire piston and usually get ignition on the very first try.
>These fire pistons are of my own design, and are the result of many prototype models. I found that the method I use is more reliable than a two hand fire piston, and causes much less fatigue on the hands during practice and actual use
Videos of my fire pistons:
Quick Press method
Slam Fire method
Shipping is free to USA buyers. International buyers please email first .
I usually ship out within two or three days of purchase.
Due to the small quantity and profit I make on these, returns cannot be accepted. Thank you.
If you have any questions, please feel free to ask.
